Hi all,
I've recently purchased a ground floor flat which I'm intending on removing the wall between kitchen and lounge ton create more space..
The plan is to remove the entire wall as drawn in red below in the L shape it is now (even the wall under the stair case. upstairs neighbours have already removed their wall which would have sat on top of this wall. My builder and neighbour both state its a non load bearing wall and will not require an RSJ and can be pulled down.
Both confirm the joists run from the back of the house to the front.
The other issue i have the the wall separating the kitchen and lounge has had previously subsided and had underpinning done on it. would removing the wall be an issue in regards to this?
ps the door leading into the bathroom from kitchen lined in green will be bricked up.
can anyone shed any advise on removing the wall & whether an RSJ be required?
