Removing Wall Hung Gas Fire and Ventilation
8 Nov 2014
Yorkshire
Hi all ,
I hope you can help with the following questions I have .
I need a wall hung gas fire removing and the supply capping off(below floorboards level).
The house is a 190 30's ish semi, normal construction the chimney has a cowl on but is not capped off.
My questions are;
Do i need to fit a ventilation grill in the chimney breast ?, we are hoping to take it back to bare bricks and partially replace the bricks where the fire entered the chimney breast with matching bricks.
should the chimney be capped off and if so does this remove the need for ventilating the chimney ?
many thanks in advance for any advice given
Glenn
Hi Dan ,
Thanks for that I appreciate that the person doing the job should know the correct methodology ,
I just want to know what would be the correct practice for this job as I don't want to it to be done improperly .
Many Thanks
Glenn
Hi Dan ,
I am sorry you feel that way , I cannot see anywhere in my posts where I have second guessed your skills or responses .
I have always found the DiyNot forums to have excellent resources and have had helpful replies to any questions I may have regarding tasks or jobs that I require doing .
I find it helps if I know what is required when I have 'professionals' and can ask better questions regarding the work required if I have an idea of what the task involves .
Nobody likes to feel that they have had their 'pants down' on any work done .
With regard to 'no idea' that was the whole point of asking someone who does have an idea
Hope you have a nice day and never get the same response from a doctor or consultant about something you have 'no idea' about.
regards
Glenn
Although you might not be considering doing the gas work, the questions your asking sort of imply your doing it yourself hence the reason your questions are not being answered and no advice given, that's the feeling I got anyway. I may be wrong, but as Dan said if you get someone decent they should give you a decent price, once the fires out and disconnected you could ask on the building forum how to sort the chimney and do that yourself if your not reusing it for anything else.
Thank You Cgas ,
I intend to get someone in to cap off the gas , but hopefully will do the rest myself
Many Thanks
Glenn
