I've removed the lamps and am planning on securing display cabinets where they were, preventing access to the wiring. I'm aware that the wiring must remain easily accessible as connector strips have been used. These wall lamps are downstairs and all the wires come down vertically to where they are.
Neither of the wall lamps are at the end of the radial circuit.
As far as I'm aware, I have 2 options:
1) Remove the switched live wires and the wiring specific to the wall lamps, lift the upstairs floorboards and make a secure soldered connection which can safely be left without access. Then I can fill the holes as no wires would be there.
2) Disconnect the switch lived wiring, leave the wall lamp wiring in the wall but create a secure soldered connection between the other lights in the circuit at this point. Cover with a blank wall plate and install the fitted furniture.
I would prefer to do 2 now and 1 at a later date. There are old fitted wardrobes upstairs over the floorboards I'd need to lift and it'll be a pain to get access.
Is this okay? Do you have any suggestions? Thanks.
