removing wall making open plan living fire blanket ?
9 Apr 2013
London
removing wall making open plan living in the top floor of a flat referb building inspector says i need a fire blanket ? in the roof whats that all about does he mean needs to be a fire wall if the terrice house are connected together ?
A fire blanket is one of those things you see on the walls in commercial kitchens. Might be OK for a chip-pan fire, but wouldn't do much to stop fire spread between houses. :LOL:
If you are installing some fire precaution required by the BCO, you must make absolutely sure you install what he means, and not what some anonymous person on the internet thinks he means.
So you're asking in the wrong place.
JohnD is right.
By 'blanket' I assume he means 'fire compartmentation' between dwellings, requried by the building regulations part B.
Look into this, and get some proper advice.
