Renault Kangoo ATF Filler
1 May 2006
Northamptonshire
Hello,
Can anyone help me? I have a Renault Kangoo van Y-reg that needs a little ATF (Automatic Transmission Fluid) but I can't find the filler cap for the life of me. Any help will be greatly appreciated.
By the way - it is an automatic.
Cheers,
DougM
How do you know it needs topping up? Presumably you've dipped it? If so that's where the fluid goes.
dougm said:
Hello,
Cheers,
DougM
Good job you pointed that out Doug :LOL:
I appreciate you taking the time to reply. I pointed out that it is an automatic to avoid these obvious answers, but I should have also mentioned that I haven't dipped it either. I assuming the ATF is low because the engine rev's higher before shifts, etc. I'm thinking it may be pointing to low fluid.
Cheers,
Doug
