hi there, i have a 2003 renault laguna initial diesel sports estate, a while ago, the sat nav system stopped picking up the satelite signal, and we are often driving in th north sea, or irish, about the same time, our clock started playing up, when you get into the car, you can set it, and it runs, no problem, but once you have turned off the ignition, it needs to be reset again, and now, we have battery charging fault popping up in the display, just a few seconds at a time, but still anoyying, have had auto elec check this out, and i am told alternator is charging fine, and no prob;lem can be found, has anyone any idea, whats going wrong, or anyone with the same problem, thanks
