renault megane 1.4 rt "s" reg
9 Sep 2008
Tyne and Wear
can anyone tell me where the tdc sensor is located please. or is it just another name for the crank angle sensor? im having trouble starting the car, when it does start its fine but when its switched off after a run and its hot it wont start again. could it be something else all help welcome and thanx in advance
could be oxegen sensor in exhaust system or could be the cold start senso or engine temp sensor as is sometimes called
I have the 1.6 alize & AFAIK the TDC sensor is located on the r/h side of the engine as you stare under the bonnet from the front.
I had problems but cleaning it soon sorted it
You may find more info for the older models at http://www.renaultforums.co.uk/
I take it that you have not got a Haynes manual then :D
EDIT: Found it - look here
The engine is likely the same.
