I have this vehicle and it's running on only three cylinders. No 2 is out (ie, second from flywheel, I believe that's how Renault count!) I replaced the coil packs with no joy, and on changing the plugs I found small shards of metal and a bit of oil on the no 2 plug. I've carried out a compression test and sure enough No 2 is very low. It doesn't increase with a few squirts of oil so I'm assuming the rings are ok and I'm looking at either a head gasket or a burnt valve/seat. The vehicle has only done 28k miles so I'm surprised at all this. Anyone here with experience of these motors? Would a failed gasket introduce metallic shards into the pot? Or is this guaranteed to be more serious? I intend to do this work myself, so info on anything unusual to be expected would be most gratefully received. I'm led to believe that the cam belts are a bit tricky to tension properly.
