Hi Guys
Back for some advice again , I’ve just had some work down on the 03 plate Trafic.It’s generally in good order 145k on the clock
I’ve just had some Power Steering pipes renewed there was a slight leak, and the Off side wheel bearing replaced
In the past it’s had a replacement refurbished Gearbox & clutch / slave cylinder at about 90k
I’ve driven maybe 10 miles since I got the Van
Back , went out in it today everything seemed fine , steering was lovely nice & smooth , got Home turned to get into the drive , dropped it into reverse fine , needed another stab to park , drove out a little then tried reverse couldn’t get it , and then the Van started with
The signs of a clutch burn out , stinky etc , it’s just drivable now , but I’m sure the Clutch has gone (still no reverse)
Is this just unlucky or somehow linked to the work they may have done when fixing the 1st problem (Power Steering)
Any info or advice would be appreciated
Phil
Phil
