My garden wall is about 2 metres high by 10 metres long and made of high density breeze block. When it was constructed one side was painted and the other rendered. It was built in 1979. I moved in about 20 years ago and have had it re-rendered twice. The render is now failing again, blowing from the wall and paint flaking off. The wall itself appears to be quite solid but there is a fair bit of green algae on it. It is not a retaining wall being purely a boundary wall
My thinking is that moisture is getting into the wall from the painted side and causing the problem with the render and also encouraging the algae.
Would it be possible to tank the painted side of the wall to prevent water ingress? I would then have the render removed and redone by a professional.
I have read that tanking should not be applied to painted walls but as this is to prevent the tanking being "pushed" off the wall by moisture seeping through, it would not be an issue here as any moisture would be coming on to it from the outside.
I would be grateful for any advice.
