Hi Everyone,
I'm unsure whether i need to render our internal walls or not.
We are doing up a mid terreace property in Sheffield and it has emerged that when they were built (1900), they used slag from the steel works, instead of sand in the cement. This has made the mortar quite crumbly and although the walls still feel quite sound, we don't know whether it is advisable to render the walls before we "dot and dab" them.
We are going to get a damp proof menbrance fitted to all the downstairs walls and when we spoke to the surveyor, he said that it wouldn't matter either way if the walls were rendered or not.
My question is, is it advisable to render the walls for support given that the mortar is of poor quality? If so, how far would you suggest taking the mortar back, because you could keep going until there's none there?
Or, is mortaring pointless as it's going to be plaster boarded? My concern is, that adding another layer onto a damp wall, with a DPM over the top and then plasterboard; may mean that there's more to go wrong. The last thing i want is to do everything and have render falling off behind the plasterboard and taking the DPM with it.
Any advice would be greatly appreciated and many thanks in advance.
Kind regards
Rob
Kind regards
Rob
