Hi - going to render part of a wall (2 x chimney alcoves) this weekend and have two 2.7square meter 'walls' to cover. At 15mm thick that equates to 2 x 41litres of 'render' - I presume aplied in two coats, one to flatten the wall (old house, bricks all over the place) and a finish coat to leave it flat for plastering.
Do I just measure out 41 litres of plastering sand and cement in the right ratio and add water or does the mix 'shrin' 'as the water is added...if it does - is there a formula for working out how much dry mix to make x amount of wet render?
Don't want to come up short and have to re-mix in the middle, but don't want loads left over....
Cheers,
Virgil.
Cheers,
Virgil.
