I have an external brick wall which I intend to render:
As you can see it is in a poor state and has been previously painted.
I have knocked off all the loose paint and will re-point.
My question is how do I prepare the wall to render for good adhesion do I need to consider expamet? If using expamet are 2 coats still required (scratch and final)?
Should I render right to the floor/flags, as you can see the bottom of the wall is damp?
If I am to stop short how far should I go and which beads should I use plastic or metal?
I intend to remove the existing coping, replace with new coping and then render does that order seem ok?
Based on what I have read I intend to use 1:1:5 cement, lime, Sand (2 parts building, 2 parts soft) with plasticizer for scratch and same again for final with waterproofing agent, both to a depth of 15mm –does that sound ok?
Your advice would be appreciated.
Thanks,
J
Thanks,
J
