Rendering a timber frame extention
13 Jun 2011
Essex
We have just had a two story extension built, the ground level built in block work & the first floor in timber frame.
The timber frame has been finished in render in the following way. Timber stud, then ply, a dpm, metal lath & finally render.
There is an internal air gap between the ply & the celotex insulation.
The building inspector is unhappy that water could get trapped within the structure. I do not understand how this could happen as the render has been waterproofed with additives & the dpm provides a waterproof barrier?
It would appear we have used an old fashioned method & now render is mounted on battens away from the ply.
Does anyone know where we can find documentation for this method being acceptable or suggestions on how to make it compliant?
Please any suggestions greatly appricated as he wants us to take it all down!
Better off working with him than trying to prove him wrong. Ask him if there's any way it could be salvaged. If he says no - then that's the end of it.
Agreed. You've got to work with hi.
Right or wrong, he's right .
Anyway of weep holes or something being put in to take away any water?
