My extension is being built with 215mm thick solid aircrete blocks which will need rendering. I have read loads about rendering failing on these blocks.
It seems that the render should not be stronger than the blocks............BUT even if the scratchcoat is 6;1 that's already much stronger than the blocks.
What is the foolproof way to ensure rendering is a success?
