Hey
I am about to render an old earth retaining wall in my garden and have the following questions:
1) The wall does not have a PVC sheet behind it to protect moisture from penetrating the wall and its not practical to put one behind it, should I treat the wall with some sort or waterproofing solution? If so which one.
2) The wall has been painted on parts in previous years, there is no flaking paint, do I need to remove all the paint?
3) What rendering mix should I use? The vast majority of the is clay red brick with some blue engineering bricks in it, there is also a section made from concrete blocks.
Any help and advice would be much appreciated.
Many thanks
Max
Many thanks
Max
