Rendering over stone window beams
6 Jul 2011
Yorkshire
Hello everyone.
I have just removed the stone effect cladding that was fixed over the stone beams above all my windows (external).
The beams have been scored with a cris cross pattern previously so the cladding could adhere to it.
I am just wondering if it is possible to render over this so i am left with a flat finish?
If so would i just need to do one coat of render or a few?
Thanks in advance.
Chris
Hello everyone.
Thanks in advance.
Chris
have you got a picture chris?
I will take one 2moro in the light and post it up!
ok, i probably wont be on till later as i have a kitchen to do but you might get a resonse from someone else. its always easier to give advice if you can see a picture with the description
If the criss cross's are quite deep and not full of muck I would give it a coat of sbr (dont water it down) let it pick up abit and put a tight coat on it (4-1)with w/proofer in it and give it a wavy line scratch and let it go off. When it is cured give it a wetting down build it out with a 5-1-1 mix to the thickness you want but dont make each coat more than 6-8mm... ;)
