Renewing timber cladding
30 Dec 2003
Worcestershire
My upper back wall is cladded with T & G fitted vertically. This has warped and now needs to be replaced. I wish to replace it with Shiplap running horizontally. Currently, working from the inside out, I have plaster-board, studding, T&G. A friend says, when I've done the replacement, I should have plaster-board, studding, insulation between studding, membrane and finally Shiplap.
I'm a bit of a novice so can someone please advise:-
1) is the suggested sequence correct ?
2) what sort of insulation ?
3) what's a membrane and where do I get one ?
from inside out;
plasterboard.
polythene vapour barrier.
timber studs and insulation.
breathable felt or otherwise.
plywood (if you want to).
cladding material.
