Hi all,
We are in the process of stripping out an old cottage that we bought 2 months ago, although with 2 young children and my husband working full time its a slow process. We have so far stripped the most of the cottage back to the stone walls and are working on the last room now. We have decided on the layout and extension and the architect is finishing the plans in the next few days. I have been reading many of the posts on here for the past 4/5 months and it has all been really helpful but I'm hoping by running my plans past you all someone might spot anything I've missed before its too late !?
We are short of space in the existing cottage so we are restricted on insulation, bus basically we are re-framing the cottage walls with 50mm kingspan K12 in the frame then 50mm K18 on top and will be sealing and taping carefully. The ceiling of the bungalow is just some wooden paneling there is currently no insulation at all and I'm still trying to decide what to do for best. Similarly the suspended timber floor only has about 25cm below it so I was thinking about attaching netting and siting rock wool or similar on top.....but I would like a completely sealing insulation box within the house and sealing the soft insulation to the rigid boards is confusing me...as is getting around the cold bridging from the floor joists ?
As far as ventilation goes I am hoping the by leaving a 30-50mm gap between the walls and the framing that the ventilation around the outside of my box and sealing the insulation well that it will be enough to keep the walls dry ( or as dry as they get..stone walls and lime mortar.)
In house we will be having two viking house 'breathing windows' and on there advice a humidity motion sensor extractor in the bathroom.
I could go on for pages but if you've made it this far then well done ! Any thoughts/advice much appreciated
