Repainting skirting boards question
22 Aug 2014
Hello. When we purchased our house(first house) the bathroom skirting were new. I painted them (no primer, just two coats of paints) bit now I'm noticing knots in the wood showing through.
If I wanted to repaint or cover these would I sand back slightly, then paint a couple more coats over. Or sand back and prime first this time and the paint?
Knots need to be sealed with knotting solution (shellac), to prevent bleeding through paint
Or you can use Aluminium Wood Primer, which I prefer.
I too normally go for a shellac based paint. Aluminium Wood Primer is a good call but may require more coats of undercoat to obliterate the Aluminium colour.
I have seen persistent knots bleed through shellac, in some cases I have had to pull the knots out, have you experienced the same with the Aluminium Wood Primer? TBH it is years since I used Aluminium Wood Primer.
not that I recall. It is very durable and I used to use it for windows and especially wooden sills. I would automatically use it on exterior glossed woodwork, but I haven't got any now. Only stained or oiled.
Thanks for responses. So if I were to purchase one of these items would I still need to run down the painted skirting boards or simply paint directly on top? And I assume I then need my satin wood white paint or whatever on top of this ?
Try Zinsser B I N - it's shellac based and white - but apply with a cheap brush and throw away because it's not easy/worth cleaning out.;) So rub down, spot prime the knots showing through, then carry on.
I used to use cheap throw away brushes until I discovered that household ammonia completely breaks it down. I just pour a little ammonia into a suitably sized container and swish the brush around for a moment or two. If the brush had started going hard, I leave it in the ammonia overnight. By morning the ammonia has evaporated off and I am left with the brush sitting in water with white dust in the bottom. I then rinse the brush under a tap and pour the waste liquid from the container down the sink. Once the sink has been rinsed no residue remains.
I wish cleaning oil based brushes was so straight forward.
