I have a tiny chip in the middle of a ceramic floor tile. Is there any way I can do a small invisible repair job rather than remove and replace a whole tile from the middle of a floor. Many thanks.
Not really, I'd just pull it aout and replace it, assuming you have spares.
Take your time removing it, cut all the grout out from around the tile then break the tile from the centre outwards, never at any point try to lever it up around the outside, you will chip other tiles.
