- Joined
- 3 Mar 2025
- Messages
- 4
- Reaction score
- 0
- Country
Got a positive input ventilation unit in the hallway of my apartment. The contractor, or somebody working for him, bored a new 100mm hole out through the gable wall of the apartment building. The wall consists of 44 centimeters of concrete block, and then a cavity, and then red brick. There's no external cover of any sort on the hole in the red brick because it's completely inaccessible from the outside. There's another building just a few inches away. The hole is about 7 feet off the ground. It's a ground floor apartment.
The problem I have now is that rats can gain access to the cavity from the outside and have free rein to run around the walls and ceiling. Also, my quick Google research tells me there should be a fire sleeve or something in there as well. Don't don't know if this is correct.
How would you even begin to fix this? Filling the 100mm hole through the concrete seems doable but what about the red brick on the outside? Getting at the red brick wall when your only path to it is a hundred millimeter hole through a 44 centimeter wall seems impossible.
