Repair joist. Acro prop while I do it?
17 Feb 2006
House built in 1927. Semi. 4 foot space under ground floor.
Just doing some tidying up. Notice a cracked joist. The timber looks completely sound, as does all the timber under the house. It's a sort of zig zag split from top to bottom. But there is lateral displacement, i.e. if I look at the joist from underneath the 2 halves of the joist are out of line, by a couple of millis. So I think the split goes all the way through.
I'll repair. What do I do? I'm guessing stainless steel coach screws to fix another joist the same size to the side of the existing? Or coach bolts and nuts? Do I need to prop anything while I do it to get the joist back up to level?
Thanks, Mike
picture will help
if its fully along and following the grain its unlikley to effect the strength
Sister joist, no need to prop unless there has been significant movement.
