We have a standard (vented/ indirect hot water tank) system. Over the last few years the efficiency of the boiler (sited in the kitchen) has plummeted.
On cold days the water from the boiler is only hand hot at the water pump (1st floor airing cupboard) but is enough to heat the hot water during the summer. The boiler thermostat (probe into the combustion area) has been replace to no effect. I have recently used descaler on the system with no improvement
The boiler is an Ideal 'E' and over 30 years old so has probably paid for its keep.
I am thinking of having the boiler replaced together with the lower pipe runs as they do not have proper drain points. Am I thinking on the right lines?
I was thinking of a WS 40CDI boiler until I read your comments on difficulty of repairing their boilers. Which boilers should I be looking at? The house is a 3 bed large semi with solid walls and we are thinking about a loft extension. Looking for a wall mounted SEDBUC A rated unit closer to 98% efficiency that is simple to repair and will give another 30 years!
