Hello all. I have a roof problem that I'm hoping I can get some advice on.
I have a two floor 1907 farmhouse that has a ground floor gable end extension. The extension has a slate roof and the abutment between the extension roof and the wall of the main farmhosue is weatherproofed by lead flashing. The lead is cut into the stone of the gable end, drops about 4 inches to the roof line, then travels about 4-5 inches to the slates where it then sits underneath the first column. The end of the lead under the slates has historically had a lipped curve, so that any water running under the slates is directed downwards to the gutter.
However, over time, the lip has become flattened along the line of the lead under the slates and is now a flat fold. That means that water coming off the lead is dropping off the end of the lead under the tiles and through the boards underneath into the attic of the extension. It's then soaking into the rafters and is making its way into the plaster of the extension walls.
So, I'm trying to figure out what's the best fix. There's about 11 linear metres of lead on both sides of the roof at the moment. So getting underneath the slates and tryign to restore the lip might take some time. The alternative, I think is taking the lead up (and maybe off) and putting in new soakers. But I'm not sure how much a job like that would cost.
Any thoughts and advice appreciated.
Brian
Brian
