Repair or Replacement?
15 Jul 2012
I have just found out my toilet flush is not working. It is a button flush.
When I took the top off the cistern I found the plastic attachment that fits to the underside of the button was loose and not connected to the mechanism. Let me see if I can describe it. Connected to the button is a white plastic arm which moves up and down. On the top of the valve that allows the water into the bowl is another shorter arm with an oblong piece of plastic shaped like a photo frame at the far end. This arm comes up to allow the water out of the cistern. It looks like the longer arm should go through this 'photo frame' but there is a piece of plastic on the longer arm that is preventing it. Is it possible to repair this mechanism or do I have to replace it? I can't see any bits of plastic or springs in the cistern. I like to do repairs myself if I can. I do hope someone can help.
