or cut the decking back to the nearest joists fit new deck then torch on some 2mm felt to level with existing roof surface, finish with 4mm capsheet to cover the whole patch.........or get a roofer
is there a good sound lead slate fitted where the pipe went through . If so put an upturned bucket over it then get a lead cap made to size to replace the bucket
