after having a 2 metre approx square section of flooring laid with a sand/cement mix by a guy i know..it has now cracked and sounds hollow to walk over which i know is going to want ripping up and re-laying as i want to tile the floor...it is approx 20mm in depth, firstly do i need to apply a primer before the concrete mix and then what is the best way of carrying out this task..sand/cement mix but lay in 2 intervals ? or would a wickes deep fill self level mix suffice as it can do up to 50mm i hear ? advice on best way to do this guys plz cheers again
