W
wolfman1
Hi, our new home has had some previous re-pointing and repairs to cracks, only thing is they haven't coloured the mortar, so it sticks out like a sore thumb, my question is what is the correct way to remove the old mortar and how deep to go, and if there is a crack should i carry out any other procedure i believe you can glue some ties in? I'm no builder so any help will be useful, i thought maybe i should grind down the middle of the joint and tap the mortar from the bricks and then refill and point? Also the mortar is a sandy colour so do i just mix some die in to normal cement, is it worth experimenting with the colour first to determin the correct quantity needed, or is there a standard sort of mix.
