repairing damage to brickwork
10 Aug 2005
Cambridgeshire
Hello all,
Recently had plumbers in to install central heating and where they have drilled holes to outside I have lost about 1" deep worth of brick.
what I mean is there is a nice clean hole on the inside but onthe outside part of the brick fell out rather than have a nice hole in it.
What is the best way to repair it and to help it blend in?
I also have a couple of holes from where they have removed pipes and some advice on how to fill them would be great too.
Regards
Wayne
what is the age of the property :?:
is the mortar a rich mix or is it soft. :?:
were is the damp proof course in relation to the damaged bricks :?:
can you obtain bricks which match the house brick :?:
waynes said:
Hello all,
Wayne
This is what happens when you use an SDS drill - the hammer action is sometimes too powerful,and hammers its way through the last bit,rather than drilling (yes,I did the same thing when drilling a hole for the SWA cable for my workshop :oops: )
should I expect the plumbers to make good the damage they have done then if it was caused by the hammer action?
as for the previous questions:
The house was built 1950ish
Mortar mix is, not sure on the difference but is quite sandy and can easily be dug out - I think
Damp proof is below the bricks
No idea about matching the bricks, i will try to find out - I take it you are suggesting removing the bricks and replacing them? sounds like a lot of work, is it?
We used to cut the holes with hammer+chisel and make good.....But then I`m one of the old school NOT rich Plumbers...worked for a firm once Boss said" we`ll send brickie round".. at job end customer said to me " That`s Bum awfull brickwork"...he was an Aus.:cool: Reckon yours is BA too. You get a lot of BA`s in Cambridge, don`t you?...same as Oxford....Red Brick with holes.
well we will see what happens looks like they may have to move the boiler they just plumbed in anyway as you cant open the front - the fusebox is in the way and I dont trust them to move that!
Shame you dont know what a companys workmanship is like until after the job...
If they drill any more holes they should use a pilot drill first then drill from each side. Saves problems with broken bricks.
