I have always had damp in one corner of my bedroom behind a bedside table. I'm redecorating the room this weekend and on lifting the laminate the concrete floor was cracked/damaged in the corner, and the laminate that from that corner was swollen, so clearly getting damp. I've pulled out the bits of broken concrete and can see the DPM which runs down the inside of the wall and presumably goes under the floor further down, but it does look like its split a little bit.
What would be the best way to fix this? Can I just put some kind of sealant on the split, then fill the hole with concrete? Or is there a better solution?
