Under my kitchen sink, about 2 inches past the stopcock, the guy who used to own my house had the wisdom to install a cheap & nasty cartridge-type water softener, using one of those fittings that just drill into the copper pipe and then seal themselves.
I've now removed most of the kit and the daft tap that used to be alongside the sink. But I'm stuck on how to remove the fitting on the rising main - currently I've left it in place and I've just clamped the original flexible tube coming from it.
Obviously this needs a more permanent solution - but what can I use to seal a small hole in a copper pipe carrying full mains pressure? The length of pipe concerned is only about 1.5 inches long.
I'm not enough of a plumber to replace the pipe section and the fittings around it - so what I'm really after is a quick off-the-shelf solution. Is there such a thing?
Cheers
Cheers
