Is there any chance someone could give me some info re. the following
south wales typical terraced property, rendered? outside with pebbledash. Plastered interior walls. I have hacked off some plaster from around a bedroom window due to damp ingress (now fixed due to leaky gutter) and have to repair hacked area. The walls are solid about 20" thick made from bricks and black mortar and plastered finish is 25mm thick but its not solid plaster.
I'm thinking of using Hardwall 2 or 3 separate coats then finishing plaster on top to blend in to surrounding plaster. I'm looking for an adequate job not a pristine one hence DIYing it but dont want the new plaster to crack or fall off 12 mths later due to wrong materials or techniques.
Am I on the right track with the above as an adequate repair to the damaged area?
