Hi, and thanks in advance for any help offered.
I need to paint my house both to protect against the weather and for appearance.
The original part of the house is timber frame (from about 1800) with weatherboarding.
The newer part (about half of the house) is block built.
Both of these sections have been pebbledashed and then rendered. The house was last painted about 7 years ago.
I have quite a few small cracks all over the house.
Some are hairline, can I just paint over these?
Some are bigger but less than 2mm. Do i need to dig these out and fill? If so, is an angle grinder, PVA then off the shelf render repair stuff the way forwards?
The biggest concern is cracks under each of the windows in the new part of the house. As mentioned above, this is blocks and render only. For these, people have suggested I angle grind the crack and fill with mastick then smooth off with an alcohol pad. Whilst some have suggested mastick then render on top to form the surface, others have suggested that this new, thin render will probably crack off very soon after.
Finally, any recommendations on masonry paint? My wallet sugests own brand, but would value any advice
Cheers
Tom
Cheers
Tom
