- Joined
- 29 Oct 2009
- Messages
- 426
- Reaction score
- 31
- Country
Hello all,
Over the winter it became aparent that the guttering on my house is not working properly.
It is white half hexagon type guttering with square down pipes.
There are some areas which are bowed, other areas which have shrubs growing up there and some where water from a downpipe is jetisoned onto the flat roof then runs off into the next section. These are all areas which I am comfortable rectifying.
The areas of concers are.
THere are various joins along the gutter where water leaks through the joins. Is there any sealant/glue/chemical weld which I could use to re joint them.
along a side extension the water seems to run down the side of the roof then miss the guttering and runs down the wall. althought the guttering is below the edge of the roof and fairly close to the block work under the overhang.
And lastly how the down pipes at front and back go straught into the ground. How can I test that where ever they drain to is working. I am not sure as It is an old house so if there is a soakaway or a rain water drain etc.
I live in an end terrace. 4 in total and the neighbour incidently does not have any down pipes.... so all his roof water runs through my guttering and into my down pipes. Is this a usual arrangement? And if the soakaways are not working should we both be getting our hands in our pockets?
Thanks in advance.
Rob
Thanks in advance.
Rob
