Hi
I've just moved into a new place that needs a lot doing to it (so you might hear from me a lot!) and at the moment I need some advice about the bathroom floor.
Its currently tiled with irregular shaped and sized mosaic tiles which are really nice and I'd like to keep them if possible. The problem is that the grout is really badly done, it has set on to the surface of a lot of tiles, and is pitted and uneven between them. Its also rather badly discoloured and is breaking away at the edge of the tiles near the bathroom door. Is it possible to replace the grout and keep the tiles? If so, any tips on how to tackle the job would be greatly appreciated
thanks loads in advance
Edit: I should mention that the tiles range from about 1/2" diameter to 1 1/2", so pretty small and lots of 'em.
