- Joined
- 14 Jul 2023
- Messages
- 15
- Reaction score
- 1
- Country
We've removed lining paper in our Victorian terrace to uncover lime plaster as shown in the photo. It's largely intact, but covered in tiny cracks and with numerous areas that feel hollow to the tap (though are clearly sounds enough that they didn't come off with the lining paper). One patch about 20x20cm in the middle top of the picture has come away entirely to expose the brick. From research I've identified two options:
1) Try to repair the lime plaster. Local builder's merchant will make up lime putty so could fill the big hole to near flush then finish with a standard filler. No experience of this and a bit nervous. Presume I'd also need to knock out all the hollow sounding areas... Then use a breathable clay paint.
2) Get rid of the lime plaster, board the wall and get it skimmed. As it's internal I guess dot and dab would be fine as I can't see any bridging issues. People warn against trapping the damp in the wall, but it's been covered in thick lining paper followed by multiple coats of emulsion on each side and seems to be dry (though the lining paper is peeling and plaster is in bad condition...)
I feel a bit out of my depth and the trades I've spoken to don't seem that well versed in lime plaster, so any input appreciated!
