A little bit of advice please.
I am repairing my boundary wall, as the previous property owner had built a fence on top of the wall, single skin block work 100mm width. The fence was bolted to the top (badly) and in the wind it has caused the top two runs of blocks to become loose. Separating them from the lower courses.
Can I remove the loose blocks, clean the surface of any mortar and build up new? Or should I do something else to fix the new blocks to old?
Secondly I want to add another run to an undamaged part of the wall but the top surface has been painted. Assumed masonry. Do I need to remove the paint before adding a new layer of blocks to help the mortar bond?
The new fence will be posted in my side of the wall so the wall will be free of the loading.
Many thanks ![/list][/wiki]
