Hi
I am in the process of renovating my house and this has included removing some walls and replacing some parts of the plasterboard walls and ceiling where there was significant damage. I am planning on getting a plasterer in to undertake a final skim coat and want to prepare the walls as much as possible to ready for him to skim so that I can get more walls done with my available funds.
The question I have is, where I have sections of new plasterboard there is a 5mm difference in the depth of the wall/ceiling to the old walls. Could you please advise me what preparation you would recommend in this case?
- I can scrim tape the gaps and screws and PVA the walls.
- I could also plaster the walls up to the same level as the rest of the wall and use my feather edge to make sure it is level. I have done this already where I had bare brick that I have had to prepare.
What are your views? I can imagine the easiest walls to plaster are ones that are already the same depth?
Finally, if you do recommend levelling the walls, what is best to use? I have both browning plaster and multi-finish open for a few other jobs I am doing. It looks like the backing layer of plaster on the original walls is a grey version of bonding plaster as it is more crumbly than finishing plaster.
Thanks for your help,
Jon
Jon
