Got a small problem on a flat roof at the front of the house. The felt is generally ok, but close to the edge there is a recess in the roof that forms a gutter, the felt has cracked in the U (on the house side of the U) - drawn a diagram to illustrate
Now I could get a roofer to redo the whole thing (it's probably about 9 square meters so estimate I'd be paying about 250 quid based on what I've read here on per meter prices..... But I was considering trying to patch it by effectively laying a strip of new felt across the channel as per this diagram
Is this a good idea since it's a patch? If I can do it should I just use a single layer of felt? And what should I use - adhesive or proper bitumen? Also how clean will I need to get the existing layer of felt or should I remove it?
