Quick question please.
I assume the replacement of this valve is straightforward. 3/4" part 1 HP. I also assume the cold water pipe slides into the brass float valve. However I would like to know what seals the copper cold water pipe to the brass valve body . Is there an olive below the screwed ring holding the cold water pipe in place or is it by plumbers tape ?
What size of olive would it be ? The Float Valve was supplied by B&Q and came without an olive.
If it was an olive could I chance slackening the nut withdrawing the pipe from valve, replace valve and re-tighten ?
