Pressurised, sealed. I was under the assumption if I don't vent any of the other rads then suction would prevent a large sum of water from vacating.Yes, it will depend whether you have a pressurised, sealed system, or a gravity fed system as to which method you use,
Either way, you won't be able to solder a joint as the pipe will be full of water.
The op needs to cut into pipework and extend it, not just change a valve.1. You do it at your own risk.
2. In theory, a sealed (and therefore pressurised) system will not leak further from a single point of exit once a partial vacuum has been established. In practice, a faulty automatic air vent, or a slight leak at a joint, can break the vacuum. If you know what you are doing, you can cap the leak / work very fast or whatever it takes to cope with it. If you are less experienced you may no know what to do and get wet.
3. If you are going to try it:
3.1 Close both valves and empty the radiator.
3.2 Slacken valve to pipework nut, drain until water stops flowing.
3.3 Remove valve and install new one. Make sure it is closed.
3.4 Repeat for other valve if required.
3.5 Do not try and remove both valves at once.
How are you proposing to drain just the section of pipe ?I will obviously drain down that pipe section, I just don't want to have to drain down every rad.
Draincock.How are you proposing to drain just the section of pipe ?
Yes ,every time premises have no external stopcock and the internal stopcock is goosed, which seems to be quite common in my neck of the woods.Do plumbers ever use freeze kits?
they always seem a bit scary to me
Great ,where is the drain cock in relation to the pipe you intend to cut into and extend ?Draincock.
Underneath it.Great ,where is the drain cock in relation to the pipe you intend to cut into and extend ?
