Replace 10mm microbore in 3 bed 2 bath flat ?
1 Dec 2011
Surrey
The flat is nearly 50 years old, radiators and pipework is all from that time, etc.
We will be knocking through to create an open plan kitchen and replacing two bathrooms, so quite a big project already.
There are 8 radiators, all on microbore where both pipes are visible at one end of the radiator and they are very ugly. There are also 2 hot water heated towel rails which would be better on electric (presumably) as I want them warm 24/7/365. I guess in theory (as there is no hot water tank) that a circuit could be created to run these on hot water but I don't see the point. Boiler is Navien.
I'm trying to get both an idea of cost and the length of time it would take to replace with copper (not interested in plastic).
As it's an online forum then without knowing the layout, ease of access, locations of everything etc then any price would be a pure guess.
If you want the towel rads on permanently then yes, electric would be be the logical choice
I would do it opportunistically, yes. It will let you use a lower flow temperature which is more efficient.
