I want to replace a Honeywell T6360B manual room thermostat with a programmable one - does anyone know of a compatible model? The current unit has 3 wires + earth and is wired to a master control centre on the underfloor heating.
The Honeywell CM901/907 (24 hour/7 day wired) or CM921/927 (wireless versions) are suitable.
If you already have a timer for the underfloor, this will have to be set to continuous (24hr on) so it does not conflict with the new programmable stat.
