Hi there,
I need to replace this broken bath cold water tap. I will have to replace the hot tap too as I can't get an identical replacement cold tap.
Questions:
0. What size spanner / wrench do I need as the one I have is too small for this job; the black nut is larger than the brass coloured one.
1. Do I undo the brass coloured nut to release the tap tail from the feed pipe?
2. Then undo the black plastic nut under the rim of the bath to release the tap itself?
3. Is this a compression joint with an olive or just a screw on joint?
4. To fit the new tap, is this just a reversal of the above?
5. Do I need to use some wraps of PTFE tape?
Thanks a lot for your helpful replies.
Mutley56 View media item 32040 View media item 32041 View media item 32042
Questions:
