Hi all,
Just to pick your brains on here.
I have a battery that's 4 years old, and googled about to find any info. on signs it may need changing.
I googled somewhere that said it should be 12.6 - 12.45 volts after being left overnight.
I tried mine, Mine's and was 12.25 after being left overnight.
So I then used the multimeter to test the amp drain which was 60 milli amps. (within limits by the internet) testing between the disconnected neg. lead and the neg. Battery post.
A few nights ago, I left a trickle charger on it overnight, and got it to 12.6v
I have been to Halfords yesterday, ( a 4 mile drive so hopefully was charged up) the alternator tested fine, and so did the battery, but was told it needed re-charging.. (it measured 12.4v at Halfords) The guy there said the battery is fine and needs charging up.
So, today I went to another Halfords, (a 10 mile run) same result..
"Battery Fine, just needs charging up"
I could try charging the battery, then with the neg. lead off, check if there's a drop in voltage overnight.
Any comments??
Any comments??
