Hi again,
Following my other thread about the water regulator I also wanted to know generally what thoughts are about the heating system and If I should invest in replacing.
I have a conventional boiler (Glow worm Micron 60FF) in situ with a Gledhill Systemate 2000 thermal store (Id never heard of these before). It's obviously not like a vented or unvented cylinder. They are both 14 years old.
The house I have moved into is much bigger than my last (3 storey, 5 bed with 2 ensuites and a main bathroom). I assume this would rule out a combi boiler due to potential demand - even a big 40kW Baxi for example?
This would leave the option of an unvented cylinder with system boiler. My current system seems to work fine, but no idea how inefficient it is compared to replacing and it is worth the investment considering the cost of replacing (?around £3k?). Or would the general consensus be to do nothing for now and wait until it breaks down and then re-look at things?
Obviously no right or wrong answer here, just after general consensus.
