I’m looking for some advice. I have recently moved into a ground floor flat (leasehold), with 3 flats above me, in an old Victorian conversion. I’m planning on renovating my bathroom and have a problem pipe in the corner of the room where I want the bath to go, boxed in with a valve key sticking out. It looks very old. If I close the valve the cold water taps in my bathroom significantly slow, although the flow doesn’t stop completely (possibly the valve isn’t great), but the water in my kitchen is unaffected. I am concluding, therefore, that whilst my kitchen is mains fed, my bathroom is on an indirect system, fed by a cold water tank in the loft.
Since I don’t want the pipe there, don’t like the idea of brushing my teeth in old tank water, and have a combi boiler now, my preference would just be to cap this pipe and re-route cold water to the bathroom from the mains. I am on the ground floor so wouldn’t anticipate any impact to water pressure, but I am worried that I might impact water pressure for the other flats if I do this? Does anyone see any issues with this plan that I should be aware of? I'm also a little concerned that I may need to get Freeholder permission for this. The only other alternative that I see is to chase the pipes into the wall and remove the valve, instead having a valve on each of the sanitaryware pieces – bath, sink, toilet.
Would welcome suggestions.
