C
Coniferman
I am in the process of pulling up and relaying some paving slabs that go around a corner of my house. (They needed re-levelling and pointing)
I am wondering whether to take the opportunity to replace the gutter drainage hopper. (Hope that is the correct term) It is a double sized hopper but the drain comes down in the middle so a single would probably suit better? (and cut down splashes) If I wanted to remove it is just a case of giving it a good tug? It seems quite free to move but does not just lift easily. Is it likely to be glued?
Secondly, if I do leave it (probably best - don't want to damage drains) is it ok just to concrete around it? The soil/concrete around it is too loose to support the paving slab going straight back down.
