A 40mm plastic waste pipe coming out of my kitchen wall is solvent welded in. The bend is cracked just by the wall so it needs replacing as does the pipe running into the new waste.
Is it possible to mechanically remove the bend if I am careful leaving the pipe intact? Or is this going to leave the pipe worthless (unable to chemically weld or add push-fit replacement bend)?
Alternatively, perhaps there is an alternative glue to fit the new bend to the old pipe?
